TwinTurbo.NET: Nissan 300ZX forum - Z1 full flow oil cooler installed (M1 0-W40)
Subject Z1 full flow oil cooler installed (M1 0-W40)
Posted by njz on March 09, 2016 at 8:31 AM
  This message has been viewed 1099 times.
Message the Z1 oil cooler kit is of good quality with excellent fitman. I took the extra time to remove intake pipe and tension rod brace to keep the hoses close to the frame.
I also left the greedy oil sandwich block in place for the aftermarket gauges. oil Temp & oil pressure. The aftermarket oil pressure measures pressure between the oil pump and oil cooler The stock oil pressure measures between oil filter out to engine. @ 3K the oil pressure at the pump is 80-90 PSI and 60 PSI on the engine. A good oil cooler (Earls) is a must.
As government expands, liberty contracts.” – Ronald Reagan
